I fitted my amp and sub woofer all on my own yesterday in the rain!!!!!!
Works a treat too. However, I made a bit of a boo boo when I connected the power lead to the battery positive terminal without first disconnecting the negative terminal - then as I went to thread the lead through the grommet into the footwell it ouched the side of the engine bay and sparks flew..... I shaht myself and then realised I should connect it all to he mains last........
Got it all in, even took some of the dash off to do it!!!! and had to cut a hole or two in the carpet to thread through... I used one of the bolts into the bodywork in the boot to install the ground cable and it all now works a treat :O).
The sound out of it is AWESOME - I am glad I did it.....
Aren't I clever?
Aren't I clever?
 Muppet. Glad to hear you got it sorted though, eventually.
