The high level LED brake light, in the spoiler, as stopped working and appears to be full of water anyone know where can I get a replacement from?
replacement high level brake light
First of all, what vehicle is it, you could try roughtrax or milners, or look in the parts for sale section on this forum.
Secondly, you could try draining the water out and checking the fuse( it must be a separate one, or the other brake lights would also be out) and replacing that, and then sealing the light fitting with silicone sealant.Rob
Still working for the man!
