I know its another Q about the rear window but this is slightly differant.
i was asked about fitting another switch to operate the rear window but have it wired so you don't need the ignition on.It will be put in the boot area so if he was sleeping in the surf he could just flick the switch to lower the rear window without having the keys in the ignition.Any thoughts on the best way to wire in a switch for it please
