Hi Snake
Yes i have replaced this bulb.
Its a bit fidly.
Remove front face off heater controls.
And there are some screws behind undo these.
And put your hand in and twist the bulb its on a sort of house light bulb fitting.only dolls house size...
If bulb has blown go to one of your local car acc shops.
i used a ford bulb, but had to remove the plastic sleve it was in.
Works a treat.
Hope this helps.
Its a bit fidly.
Works a treat.
Hope this helps.
 AnDy
