I've trawled the group, but not really found what I need. I have a dodgy front RH side light. It works if I tap the light. I would like to get at the back to check the bulb/connections.
I've read about the 'rear access' after removing the battery/water bottle, but I can see two cross head screws on the outside of the lens (on the rearmost edge). Can I just remove these easily, and pull the lamp unit straight forwards and get at it that way, or do those screws just hold the lens on in some way.
I'd rather not take the battery out if this way makes it a 5 minute job.
Cheers... Rob.
Cheers... Rob.
