Help me pleese ¡¡¡ i need 2L-TE electrical wiring diagram
Hi I need thoses diagram to. Please help me my pradio 1991 is in the shop since 3 weeks and it`s costing me a lot. He do not start and the power don`t get to the fuel pump. We test the ECU and they seems ok but not power is getting to them.
If you did not get the ECU diagram for 2L-TE I am posting it here for you. Try it. Cheers.
I have a diagram but it won't get attached although the upload seemed to have finished ok. If you give me your e-mail address I will send it directly to your mailbox.
Thanks,
Jlikukel
Reason: Attachment won't go!
Ok guys I still need your help. I found the diagram and my problem. I had to change a sencer on the fuel pump. Now it start perfectly. But new problem. Now the engine light is on and I dont get all the power at high speed. The teck guy told me it probably the valve in the fuel pump and I need a new pump. But that pump was workink perfectly before we took everything a part and I have the feeling than it`s something else. I don`t think the turbo turns on and I was wondering if that could be my problem or if it is a reaction of a problem in the pump. Please let me know if you have any idea I dont know mutch abouth thoses engine yet.
They told me than we are getting a code 12 (Timer control valve (Pump)). But how the pump can sudently be working wrong it was fine before to get at the garage. Is there other options than changing the pump because it seems really expensive.
i think, but i haven't been and checked, the turbo pressure sensor is the one on the side of the airbox. If that's not working it won't put any more fuel in to the mixture as the turbo spools up, so you'll get little or no turbo boost, or at least that's how i think it works.
