Has anyone got any ideas as to how to cure a starting problem on my 96 3rd gen Surf.
I have a problem similar to that warduke had but having read the comments I am none the wiser on how to cure it.
When I go to start the car in the mornings or after work it struggles to cranck over and seems to have a flat battery. once it starts it flashes the indicators twice but I think this is caused by the toad cat1 alarm/immobiliser telling me of low voltage.
at first I thought it was the battery as this was the original one from japan but I have replaced this and the problem is still there with the new one (had them both checked and once charged both are good)
I had an auto electrical friend check it for a power drain once the ignition is off and also that the alternator is charging both are fine. i have now also replace the positive terminal connector as this was loose and cleaned up all connections on the earth lead (including the one on the engine block).
I am now starting to wonder what to do next as the problem is getting worse and dont want to replace the alternator or starter motor if this will not cure the problem.
