No problems after two and a half years of daily use, thanks in part to all of you on here, with all the advice shared. I've stuck my oar in if I thought it would help, now I need something specific.
Last weekend unlocked from the fob, drove for an hour, stopped, would not lock from fob. Thought to myself *****cheap battery on ebay!! Bought new battery, changed, no joy.
Am I missing something? This has happened before when I first had it and I just changed the fob battery. Is there some sequence to re-assign the fob or do I just accept that it has failed and use the key? The central locking is OK so it must be the Tx in the key or the Rx in the Surf, wherever that is.
I'm reasonably electrically competent so if anyone has any test ideas I'll be greatful!!
