Can someone help? The interior light of my 95 SSR-G does not work when the doors are opened, even though the door warning lights are on. The light operates if switched to on constant position, off in mid position, then nothing in auto position. Its annoying in these dark months.
Interior Light Not Working
Originally posted by Matt EllisCan someone help? The interior light of my 95 SSR-G does not work when the doors are opened, even though the door warning lights are on. The light operates if switched to on constant position, off in mid position, then nothing in auto position. Its annoying in these dark months.Look out Eastbourne, the Pandas are coming !
You need to remove the fitting and check that the switch is making a connection on the tracks on the back of the fitting, if its not, you may need to solder something onto the switch so that it makes a good contact. I had the same problem in my '92 SSR-G but for the rear passengers. I actually ended up drilling a hole through the track and the fitting and putting a small nut and bolt where the switch touches the track...Make any sense?When the going gets tough...The Surf gets going!!!
Originally posted by ninja_kingYou need to remove the fitting and check that the switch is making a connection on the tracks on the back of the fitting, if its not, you may need to solder something onto the switch so that it makes a good contact. I had the same problem in my '92 SSR-G but for the rear passengers. I actually ended up drilling a hole through the track and the fitting and putting a small nut and bolt where the switch touches the track...Make any sense?
Originally posted by ninja_kingLet me know how u get on
