Using the information in this link;
http://www.autoshop101.com/forms/h16.pdf
Anyone out there think it may be possible that some elecronic item/ gadget could be placed to feed the gear change solenoids so that the auto box could be configured to operate by an up and down button (not sure where to fit)
This would then give manual control of the gear changes and their timing.
From reading the link provided I gather that the gear position is basically a combination of two solenoids. See page 15 of linked pdf, 1st column.
Third solenoid is lock up
Fourth solenoid is 4WD
I reckon some digital bit and a few relays, need guidance and probable part list.
There's a challenge for all you sparkies out there!
