Hi,
My speedo isn't working. I've tried all the suggestions found on this board and have removed the dash, cleaned all the connections to the plugs, the plug pins themselves and have even removed the speedo unit (6 screws) and looked for broken wires.
A couple of posts have mentioned that "one or both of two small wires may be broken', 'too small to solder' and possible 'actually connecting the unit to the dash'.
I can't find any small wires? Other than the 6 screws which connect from the copper pads on the flexible printed sheet to contacts beneath the speedo hard PCB I can't locate anything else that may be loose.
Any advice on where I should be looking?
Cheers,
Dan
Cheers,
Dan
