it`s been intermittent going back up for a while but has now stuck down.
it`s always fine going down with key or switch and when going up it was intermittent with both key and switch.
so switch and keylock are ok
the up relay is making the right noises
all plugs and wires leading to relays look fine
does this mean it is very likely to be motor (in which case i will swap with n/s/r door) or could it be a broken wire in loom leading into tailgate?
i`m hoping the relay is ok as it`s making the same noise it did when it was working.
any help would be great.
Ian
