Hi All,
My 3.0 TD surf has the 'winterpack' with the 2 batteries. Unfortunately they have a tendancy (esp since the rubbish weather has set in) to flatten themselves so that when I try to start it in the morning, there's little to no charge left to turn the engine over.
I've changed these over the weekend for some brand new heavy duty versions, but unfortunately the problems persists. There does not appear to be a problem with the drive belts and I have definately not left any ancillaries on, so I'm guessing the alternator could be at fault and not charging correctly? or could it be worse than that and have an unidentifiable shortcircuit somewhere in the system?
Any ideas if this could be a possible factor and if so how much and where I could pick one up from?
Thanks all once again
trilogy
trilogy
