Not sure if my 96 SSRX Surf has an alarm, but when I press the lock button on the key a second time the horn gives a short beep and the doors clunk shut again. Is this a factory fitted thing?
Horn beeps when key button locked twice?
Button on key ??? Not fair! Why hasn't my '96 got oneOriginally posted by jonnyhicksNot sure if my 96 SSRX Surf has an alarm, but when I press the lock button on the key a second time the horn gives a short beep and the doors clunk shut again. Is this a factory fitted thing?
Doors clunk shut again ? sounds like dead locking, try opening the door from the inside after pressing the button the second time (does the first press lock the door?) If you can't open it then from the inside, you've activated deadlocks!!Maurice
Its the deadlocks, and alarm coming inOriginally posted by jonnyhicksNot sure if my 96 SSRX Surf has an alarm, but when I press the lock button on the key a second time the horn gives a short beep and the doors clunk shut again. Is this a factory fitted thing?
KeithI never ever apologise for anything. http://www.onestopshopformultimedia.com/smile.gif If you dont like it I am sorry but thats the way I am
No alarm, no deadlocks. Looked for these when I got it in July '03. I have got the buttons on my key and my horn toots if I press to lock a second time. I just assumed it confirms that you've locked it if you were too far away from the vehicle to hear the locks lock.
 After activating the deadlocks rock the truck and switch the interior light on and off. This will set the alarm off. You can then amuse yourself and the neighbours, while you work out how to cancel it!
