Hi,
I turned on the radio this morning, ariel went up as normal but when it got to the top of its travel, the motor kept turning, so I instantly turned the radio off and down it went no problem. can someone please let me know why the ariel motor refused to turn off when it reached the end of its travel, is it a relay fault?.If you leave it running long enough,
  it eventually turns off so maybe something is sticking or burning out.
