Keyless entry fitting?
  • Keyless entry fitting?
    Hi Ive got a keyless entry kit from ebay for my 1991 Surf but am not sure about the wiring. I think the central locking control unit is near the fuses in the drivers footwell (would appreciate if anyone could confirm). The central locking diagrams on the kit show Negative trigger, Positive trigger, Positive/Negative trigger & Pneumatic lock Im not sure what my Surf is. The wires from the keyless control unit are orange, white, yellow, org/blk, blk/wht, ylw/blk with positive feed & ground. I have a wiring diagram for the control unit but the wire colours on the keyless do not match at all. Anyone fitted one of these or able to help at all. thanks
    Here you go....http://www.hiluxsurf.co.uk/forums/sh...remote+locking
      Nice one thanks for the great link
        fitted keyless no probs
        Fitted my keyless entry kit today, the fitting instructions had wiring diagram for Negative Trigger followed this and it worked first time, no need for any extra relays. Was relatively easy when I got my head around it (which took some time) took a couple of hours bit fiddly to get to the wires you need to join into, I soldered the connections which seemed easier for me. Put the wire for the lights in at the fuses & that worked too. The threads I looked at in the forum were great and I would not have managed witout them so thanks to everyone who posted information about keyless entry.
        Another question? there is a wire on the keyless control box that can open the trunk - can this be used for the powered rear window? if so does it need to be wired to the boot switch (if so to which wire) or straigt to the motor again any advice would be great.
          <glows with pride>
          Thanks!
            SurfRunner can you please post or e-mail me the type of keyless kit you fitted
              keyless link
              hi this is the link to the keyless entry I got on ebay, the seller was good they sent one out to me but it did not arrive, so they sent another without any probs
              http://cgi.ebay.co.uk/TOYOTA-Keyless...ayphotohosting
              Their ebay shop is
              http://stores.ebay.co.uk/taxfreezone
                Thanks for that Surfrunner
