Can anyone tell me how to change a headlight bulb on a 1991 surf please.
Head lights
got to get behind the light, which means moving battery, i haven't been unfortunate enough to lose a bulb yet, so i aint tried it, but i read somewhere, i could be wrong.Originally posted by rats
[COLOR=red]Simon [/COLOR] '91 2.4td ssr-x
Undo the battery retaining arm and slide the battery back a little, 1 bolt holds the overflow bottle in place, undo that and lift the bottle up, you will see the back of the headlight then.Originally posted by rats
If you have twin batteries then do the same on the other side with the wash bottle.
No need to undo the batteries as they will move backward far enough to access the headlamps.
Replaced both of mine today with brighter lights
KeithI never ever apologise for anything. http://www.onestopshopformultimedia.com/smile.gif If you dont like it I am sorry but thats the way I am
On mine you also have to remove the air intake pipe from the passenger side behind the headlight to get at the lamp. It makes it easier to take out that battery but as Keith said the Drivers side doesn't need to come out, just slide back.Originally posted by hormygollopUndo the battery retaining arm and slide the battery back a little, 1 bolt holds the overflow bottle in place, undo that and lift the bottle up, you will see the back of the headlight then.
Keith
You can find a detailed description of how to change '91 headlights, amongst other great bits of knowledge on...
http://www.showmesome.info/hilux/wor...headlights.htm
I've done a few bit's and pieces on my '92 and even though there a re some differences between the Gen I and Gen II you get the idea!
RobRob
'92 2.4TD SSR-X AUTO
"You Sir are drunk!"
"Ahh yes Madam, but you are ugly and in the morning I shall be sober."
Is the sidelight on a 96 Surf the same idea?Originally posted by hormygollopUndo the battery retaining arm and slide the battery back a little, 1 bolt holds the overflow bottle in place, undo that and lift the bottle up, you will see the back of the headlight then.
KeithPowered by ????
