hi guys iam after a bit of help my 4wd has stoped working and i hav checked all the vacuum pipes relay etc but i hav just found out there are fuses for the 4wd and another which is called guage fuse i think. can Anyone tell me were they are i hav looked in normal places and i cant find them.
fuses
the only fuses i know of are under the bonnet ,drivers footwell and i think behind the glove box there are someOriginally posted by fraserhi guys iam after a bit of help my 4wd has stoped working and i hav checked all the vacuum pipes relay etc but i hav just found out there are fuses for the 4wd and another which is called guage fuse i think. can Anyone tell me were they are i hav looked in normal places and i cant find them.https://www.facebook.com/groups/henpals/
Hard to say as we dont know your model. Fuses are usually in 3 places (on a second Gen) in the engine compartment in the drivers kick panel and behind the glovebox.Originally posted by fraserhi guys iam after a bit of help my 4wd has stoped working and i hav checked all the vacuum pipes relay etc but i hav just found out there are fuses for the 4wd and another which is called guage fuse i think. can Anyone tell me were they are i hav looked in normal places and i cant find them.Trust your Hound.
There's an electronic control unit for the A.D.D. system behind the panel under the ashtray/cigar lighter. It may be faulty, or you've got a sticking solenoid somewhere in the ADD..
You should still be able to engage 4WD with the short transfer lever.
http://www.hiluxsurf.co.uk/forums/at...chmentid=10475
