I am waiting for my first Surf, being shipped to me from Japan (a July 1999 SSR-G TD).  Is there a (legal) replacement rear light that would include reversing and fog lamps, as well as the usual?  Would this particular model have reversing lights anyway?  Any information gratefully received ...
Rear light replacement
They will have to fit one for the SVA test, so you will have the wiring already, also after the SVA you could convert one of the reversing lights or get some Honda bumper fog lights from a s c r a p yard, they will be flush fitting into the bumper.
Some have just used the £5 rectangular types you can get fromOriginally posted by najobskalfThanks for the information - as you probably surmised, I was trying to avoid the under-bumper "pendants". I suppose the only answer is to fit ones in the bumper itself (which is probably cheaper anyway), if I can find some smartish-looking ones.
Motor Factors for bumper mounting. Hole in bumper, lens in front,
case behind then screwed through to clamp onto bumper.
