Another rear window question....
  • #16
    I think next time I need something I will move my but and try looking round the s$$$$py.
    I dont know if this is what your looking for but it explains quite a bit about different specs.
    http://en.wikipedia.org/wiki/Toyota_Hilux_Surf
    • #17
      My window would rise up but stop 3 inches below the top the same as yours. If the rear door isn't closed properly then the above happens. All I had to do was to make sure I slammed the door to sort it out. My window can also be raised and lowered whilst horizontal or near horizontal so I can test if it goes the full way up. Try it - as it won't cost you anything. Just make sure you support the window as it goes up and down.
      @africa4x4cafe
      [url]www.africa4x4cafe.com[/url]
      • #18
        thanks for the info mate, but my motor was definatley knackered! It had a huge groove all through the middle of the teeth on the cog hence why it was struggling when the window got near the top.
        • #19
          Sorry - I was picking up fag ends again...glad you got it sorted.
          @africa4x4cafe
          • #20
            mines playing up
            on the key all is fine but from inside it will close (go up) but will not open
            anyone had this prob.......
            • #21
              Originally posted by john.sally
              mines playing up
              Probably a dodgy switch or a broken wire in the rubber covered loom between
              the tailgate and body.
