ok i am starting to feel a bit like a kipper here..
ad on ebay (hmmmm..) all you need to upgrade to central locking- plugs right in. seems plausible, one loom for all the models etc.. so in i dived.
big box of bits turns up today, started sorting it out, do the drivers door first. the wires through the flexi bit were badly repaired, but its off a breaker, so i chopped out all the dodgy stuff, repaired it taped it up and in it went. all works manually so run the wires through the door and when they pop out the other side one goes back in where the old bit of loom was, but i have 2 more pugs and nowhere to plug em in!
is there a control box that goes above the fuse board? have i been tucked up?
help!
help!
