Hi Guys- My 1990 Surf(2LT-E) is cutting out. Sometimes at idle it will rev up a bit but stay running, but at other times the 'Check' light will come on, the rev counter needle goes to '0' and the engine stalls.Usually at intersection(Yes- NewZealand has 3 intersections now, but more are planned)
Occasionally it will stall while driving below about 70KPH, with a large belch of exhaust smoke.
Always restarts luckily. Dealership not helpful.
Thanks in advance for any help.
). What I based my comment on is that the Toyota EPC says my engine is a 2lte.
also check the throttle position sensor, these can play up and cause the same sort of problems.
