Trying to be smart and got a remote relay switch for the rear window, but the rear window relay is negative switched, and the remote relay is suppling positive.
Does anyone have any ideas how I can get a positive feed to switch a negative, cause I can't.
The only thing I can think off is to wire direct to the motor, but this will then bypass all the safty features of the rear window relay.
