I don't know if any of you can help me, or give me any information at all....but if you could that would be great.
I recently imported a 93 Hilux surf ssr-g which came with a panasonic gps system as above kx-ga21.
I know the gps is done through a cd - has anyone had any experience obtaining a uk cd that is compatible with that unit? I know its a jap unit but surly their must be some similarities with the uk equivalent?
Also the TV tuner, i am guessing due to the fact its japanese the frequencys are not the same for the UK... is there anything I can do to make any use of this unit at all, or is it useless in the UK?
Any help, links contacts that I can get any information from would be much appreciated....
Thanks in advance.
CM
Thanks in advance.
CM
