I've just bought a Fog Light wiring kit which has all the Earth cables, relays, switches, etc.
I can understand it all except for one bit. It says to connect the wire from the switch up to the side lights instead of to the battery.
I would have assumed the red fused wire went to the + battery terminal and the wire from the switch goes to the - terminal.
Why would it connect to the side lights? Is it so the Fogs will only work when the side lights are on? Could I still connect it to the battery so they work with or without the side lights?
