Instead of hijacking someone elses rear window thread I've started this one.
I disconnected the connector to the window motor so as to test it with a 12v feed direct from the battery positive terminal. Just as I got set up it was dark and I decided to wait till daylight and go again at it.
Theres two wires going to the motor from the connector. A few questions...
1. Does the motor get pwr thru one and a ground thru the other, and then the same but in the opposite direction for the other window operation?
2. Or is each wire a 12v supply coming from the relay, one operating the motor in one direction, the other in the opposite, the motor then getting its ground from being bolted to the chassis?
3. Is it possible to take out everything bar the runners and service the lot, even the motor and then lube the runners with everything out of the way?
