Another rear window problem, goes up and down on the internal switch but wont work either on the external switch or on my alarm keyfob.
Checked all the fuses (including by accellerator)
Have also lost rear window demister and rear door open warning light on dash, rear wiper works ok.
I have got the wiring diagram http://www.afm15.dial.pipex.com/surf...ar_window1.jpg but
cannot make out the wiring colours or connection numbers into the control box as the scan is not too great.
It would appear that I have lost the unswitched supply to the control box but without knowing which wire it goes in on I can't trace back to the source.
I can hear the relay click when I use my keyfob but seems to be no voltage to operate the motor.
Anyone who can view the diagram know what the symbol to the top left of the diagram is the other two are fuses but I don't recognise that one.
