Hi Maurice, I've aimed this question mainly at you as its to do with led's but if
anyone else can help please feel free, As i said it's to do with the led's im putting in the instruments, I would like to protect them with a fuse on the supply, I know these things run on miliamps and i would not be able to get a
standard blade fuse low enough so could you tell me what size (rating) fuse
i should use and what type if poss,
I've got a lot of glass fuses of different ratings some of em small quick-blow
and some fuse carriers from maplins, Idealy i'd like to use a panel mounted
type fuse holder (like the ones you get in battery chargers etc) There easy
to change and could be fitted on the dash, The two i've got take a large
glass fuse though, Thanks for any help or thoughts, Ian.
1.5K is a more suitable resistance for a 12V supply. Worthwhile using metal film rather than carbon for reliability, as well.
