Hi just bought my first surf, i was having a good look around it when i got home and i found a switch near to the bonnet relise catch under the steering, on firther investigation i found it was connecter to the suspension switch, any ideas what it's for???? I asked the dealer that i bought it from and he has no idea?!?!?!
whats this switch??
Originally posted by mupp1tHi just bought my first surf, i was having a good look around it when i got home and i found a switch near to the bonnet relise catch under the steering, on firther investigation i found it was connecter to the suspension switch, any ideas what it's for???? I asked the dealer that i bought it from and he has no idea?!?!?!
Probably me being stupid but does your hard/soft suspension settings work.. if not it probably needs connecting to the switch??
If not then it'll either be the idle up switch or for your front or rear foglights..
Many of the switches inthe surfs are in different places.. they can range from centre console to the gear console to the panel on the roght of the steering wheel (very technical i know!)
you should have switches for the following so see whats missing
Hard soft suspension
Idle up
Fuel Cap Release
front fog lights (if not fitted the chances are the wiring will still be there)
Rear Fog Light
Rear Window
I think thats it!
JoeParanoid? They're out to GET YOU!
thank's, i found out that it's for the fog lights when i stripped all the pannels for replacing the sterio!!Originally posted by joe112Probably me being stupid but does your hard/soft suspension settings work.. if not it probably needs connecting to the switch??
Idle up
Fuel Cap Release
Rear Fog Light
Rear Window
I think thats it!
Joe
