My drivers window which has auto on the button is either open or closed. Is there a way of stopping it partially open the same as the passenger side
Why wont it stop where I want ?
They are supposed to do that Vince, but mine developed a mind of it's own. I carefully removed the drivers door arm rest and got to the underside of the switches. The connectors where all showing signs of corrosion, so I cleaned them up and soldered them. Works as good as new now.It's only a hobby!
