identify this sensor? and sleep with my wife
  • #16
    you havent got a part number have you??
    Approorx £20 from Toyota main stealers.
    or a description of what its called
    • #17
      Originally posted by Esamed
      bugger vince your fast!!!!
      So his wife says
      he he
      Well I am self employed and time is money!
      • #18
        these are the pictures
        these are the pictures thats the top piece of the sensor the bottom brass bit is what you can see in the other picture any ideas ???
        • #19
          Is your electric fan stuck on?
          If so that should be for the electric fan. Normaly the switch is closed and opens when hot which activates the fan. Hence when you have the ignition on and pull the connector off it switches the fan on
          • #20
            i didnt notice it being on
            • #21
              That bottom brass bit certainley doesn't look normal to me. By that, I mean factory fitted.
              Aftermarket something or other! Fan? Switch to switch on (or off) a heater?
              It just does, OK?
              • #22
                I've been thinking that, if the temp gauge sender is there, and theres one for the electric fan, then the third / broken sensor must be an after market 'add on' for something, maybe a fuel heater? so as long as it dose'n leak, forgedt about it!
                Am I making any sense, 'cos I've been drinking port this evening.
                • #23
                  Port!!!???
                  Ya posh git!!!!
                  I've been on the Strongbow!!!
                  It just does, OK?
                  • #24
                    The broken one is for an aftermarket temp gauge or switch of some kind. If not there then buy an extra temp gauge and install the new sensor there.
                    Nev
                    • #25
                      hehehe! yeah I know, I'm not really a drinker but we been watching that film 'A beautiful mind' eating lasagne and a few glasses of port. the misses kept filling me glass up.
                      I suspect she will tell me later there's a big scratch or something that's "appeared" on the Mondeo!
                      • #26
                        As long as it's ONLY the Mondeo!!!!!
                        It just does, OK?
