headlamp bulb
  • headlamp bulb
    n/s no low-beam
    new one at the ready
    what needs to come out
    Battery-waterbottle-air? intake
    answers on a postcard to.............
    St hilux home for the demented newbies
    Originally posted by slowdown.harrison@gmail.c
    n/s no low-beam
    You said it
      Bulb changing
      am I correct in the collective reticence,
      that I have touched on an un-spoken matter!
        The easiest way
        Laugh!!! I nearly bought my own beer.
        Paul
          No just an argument as to whether it's quicker to remove grill or remove battery. My moneys on the grill method. Done it twice that way. Changed both front bulbs in about 15 mins.
          Mike G
            Grill eh!
            Found and removed the two 10mm bolts on top side of it,
            but when it failed to budge, and I coulden't see anything else to un-do,
            I thought better than to wrench it off with a tow-rope and another car!
            as it turned out, loosening battery strap, coolant, and (the other bit)
            turned out to be enough.
            thanks for advice on both routes team, if anyone else need,
            any advice drop me a line.
