not sure but if it is factory fitted then it will need rechipping as the brother in law has this problem with his import celica but there again the speed limit is 70 so why would you need to set it any higher?
thanks keith , its a factory fit on the steering wheel if that helps any ?
I would still check and see if there is a second cable for the cruise control, which should be attached to the main throttle cable. Adjust any slack right out of it,
i normally cruise at about 80 on long journeys other wise it takes all day getting anywhere .How much did it cost to re-chip and where ?
