Hi. I'm a noob Hilux Pickup owner.
My rear tail lights stopped working last week on my way home in the dark
I've checked fuses in both boxes, changed the lighting relay, checked bulbs and looked for obvious loose connections, but can't find anything. There appear to be no earthing points at the back. They all come forward via the cab fusebox.
The front sidelights, brake, reverse and fog light all work fine. Its just the rear sides and number plate lights.
All suggestions welcome.
I've checked fuses in both boxes, changed the lighting relay, checked bulbs and looked for obvious loose connections, but can't find anything. There appear to be no earthing points at the back. They all come forward via the cab fusebox.The front sidelights, brake, reverse and fog light all work fine. Its just the rear sides and number plate lights.
