Cibies
  • Cibies
    Hi, got me some whopping 125 watt BIG Cibies up front, from a mates rally car and they luk great.
    Where do i start with wiring? is their a recommended place to site relays, take switch feed from, do most folks take main feed from battery etc etc..........
    I calculate that each lamp will pull 10.4 amps @ 125 watts /12 volts so will need a 30 amp relay and 20 amp cable to be on safe side yes?????
    These babys are like daylight when up and running.
    Al.
    I used to have a surf me!
    http://www.hiluxsurf.co.uk/forums/sh...ad.php?t=18402
    lots of discussion on that issue here.
    Those Cibies sound great. Bikenuts who posts on here had two rally car headlights on a Harris magnum style GSX1100. If it sounds improbable then thats how it looked. I still have the mental image of heading for a bike rally on unlit cheshire roads and the poor learner we made ride in front casting a perfectly defined shadow down the road. He could see everthing axcept the patch he was riding on.
      I can picture that, must have been quite a spectacle. Thanx 4 the link, i will check it out.
      Al.
