Hi, got me some whopping 125 watt BIG Cibies up front, from a mates rally car and they luk great.
Where do i start with wiring? is their a recommended place to site relays, take switch feed from, do most folks take main feed from battery etc etc..........
I calculate that each lamp will pull 10.4 amps @ 125 watts /12 volts so will need a 30 amp relay and 20 amp cable to be on safe side yes?????
These babys are like daylight when up and running.
Al.
Al.
