I'm told this is just changing a couple of screws around behind the dash.
I can't even get the dash trim off!!!!!!!!!!!!
Can anyone tell me what to do. I took the 2 top screws out and removed the 2 bottom screws, it came away at the top but it still would'nt come out?????
If I do get it out, are the reset screws obvious?
Any advice appreciated.
 ).... Remove the two screws from lower edge of trim either side of steering column. Remove screws from upper edge of panel around steering colum, remove panel. Remove small panel around ignition assy. Lower the steering column, remove two screws from upper portion of black surround of dials. Remove two screws from lower edge of the black surround of the dials (previously hidden behind lower panel).
