heater fan
  • heater fan
    My heater fan will only work on the fastest setting? i had this problem before on my nissan and replaced a circuit board, do the surfs have the same? if so where is it?
    Baz
    In mine and most toymotas there is a resistor pack mounted up above the passengers left foot.
    You may need to pull back the carpet to find it.
    I have not got my wagon here at the mo so pics are a no go.
    It is a black plastic baced jobby about as big as a box of matches with a plug in the back and 4-5 wires coming out of it.
    I took mine out and bridged it so that have 5 variations of the same speed.
    i.e fast on all settings.
    Simon.O.
    '90 SSR Ltd 2.4TD 5 spd
      Thanks for the info. Has anybody bought replacement from Toyota? the nissan one was really cheap.
      Baz
        Here is a pic of resistor location (bottom of pic) on a '92 Surf. Motor has been removed. There are two sizes. The earlier models have a resistor with exposed wires and as a result corrode and break down. The later models have a resistor where wires are encased in a ceramic block. These are larger and I don't think they will fit the earlier models.
        Nev
          Nice one, thnaks for the info
          Baz
            Got my new resistor pack today, 33 quid, new from Toyota, BARGAIN!
            the part number is - 87138-89106 Resistor, Blower
            Baz
              thanks for that baz
              Tim
                Originally posted by dirtydog
                thanks for that baz
                like the new signature pictutre.
                btw how do you add a picture to that area???
                btw happy new year
