Mystery black box?
  • Mystery black box?
    Hi fellas
    The missus has just bought a 3rd gen SSRG and I thought I'd go for a spin in it today, on getting out I noticed a black box under the drivers seat which is held down by a velcro strap and plugged into the electrics - anybody know what it is for? just wondering
    Cheers chaps
    i think its the ejector. DONT touch it
    I used to have a surf me!
      two thoughts.......something to do with immobiliser or more than likely if it has what seems to be several buttons and /or two digit face - could be turbo timer to keep the engine running for a little while after leaving the vehicle [allows the rubo to wind down - sudden hot/cold could end up to the turbo failing]
      Gaz
        Originally posted by GCob427
        Hi fellas
        Cheers chaps
        It's the central locking box.
          What aaaaaaaaaaaaaaarrrrrrrrrrrgggg gggghhhhhh
            So what is it then, just noticed one on mine - it's dark now so I will have a look in the morning
            Drink Till she's cute, but stop before the wedding
              Central locking
              Brian
                mine is for the remote central locking which i just found out it works.
                does anyone know if i can buy a key over here with the buttons on it for the central locking
                  If there is a makers name on there with a serial number, then type it into google see what comes up.
                    there's no name on the key but will have a look on the black box.
                    the lock button has come off the key but it still works ok just wanted to get a spare if i could .
                      The reason I sugested google is I've needed info on electronics / security stuff in the past and 99% of the time I've found what I was after.
                        just had a look at the black box but there is no name or anything on it.
                        i think i might just make a few enquiries and see what i can come up with and will let you know
                          You could try one of these companies.
                          http://www.alarmremotes.co.uk/products.htm
                          http://www.discountcaraudio.co.uk/key_fobs.htm
                          http://www.tech-tronics.net/mainsite/cart/remotes.htm
                            thanks Andy i will give them a try
