Hi,
I have fitted new relay to my surfboard. It is the rear window down relay.
Bought from maplins for about a quid.
Use a desoldering pump and you will find the new relay is a direct replacement, all 5 pins line up perfectly with the holes in the board and the thing works perfectly.
I bought 2 so when the up relay fails I can replace that as well.
Hope this will help someone.
Al.
Al.
