TOYOTA SURF K REG 2.4 DIESEL AUTO
Hi After 18 trouble free months my off side brake light bulb blew
I replaced it with the correct new bulb although working for a few minutes
the fuse for the brake lights (which is also the one that releases the gear lever
so you dont have to press the red button) then blew I have checked the wiring and the bulb holder both seem ok but every time I replace the fuse it blows again even if I put in a larger fuse.
any suggestions please.
