I have a new 1995 3L SSRG surf that has two batteries fitted. One looks new, the other real poor. I want to get this sorted asap as I don't want to kill my one good battery.
I want two good beefy batteries as I intend to run a few accessories....
My questions:
a) Do I just go for the biggest capacity ones that will physically fit? Or would this blow the alternator(s)? If the latter is true how do I know what would be safe battery capacitites?
b) I understand from other threads that the single battery configurations require a battery of around 700CCA. Can I just half this and get two batteries of around 350CC (if possible)?
c) Do the batteries need to be matched? ie the same?
As you can probably tell, I'm no expert at this
Advice is v.much appreciated.
Thanks,
Andrew
My questions:
Thanks,
Andrew
