Hi,
When I switch the ignition on the temp. needle rises to below halfway- which I understand to be the warm/running position. Starting and running the engine makes it rise slightly but still below half. When engine is stopped the needle returns to bottom of gauge.
Before I buy new temp. sender- has anybody had the same problem or is there a basic way of checking the sender unit. (I dont have electrical tools)
thanks,
chris
thanks,
chris
