I need to move the autochanger, as it is currently on display next to the r/h wheel arch in the back. As far as I can tell, my two best options are:
a. under the passenger seat, or
b. in the cubby-hole on the right next to the tailgate.
Option a. looks the best by far, although the non-functional navigation system is currently residing there.
First question: does removing the satnav box cause any problems with the screen, other than getting no picture (which is what I have at the moment anyway)?
Second question: does the cable from the head unit tothe autochanger run through there anyway? There appears to be a cable there with a similar plug to that going into the autochanger, and I wondered if there was an extension from under the passenger seat to the boot area (i.e. I could then unplug the extension and plug the changer straight in under the seat without having to do any tedious cable re-routing
Could find anything pertinent with the search button...
so I could do without spending the money at the moment!
