Hello
I have a 1996 SSRX with the standard a pioneer tape/tuner/cd combo. I replaced it with a JVC stereo. I found the connections by taking apart the pioneer and looking at the PCB inside which had the pin outs on it. There were 3 wires I did not use
1. ANT, which I assume, stands for antenna, which I’m not using.
2. AMP, which I think must be for an amplifier. Do I need this or is it a supply to an amp if I chose to fit one?
3. ILL, I do not know what this is for ???
Now that the job is finished the light at the AUTO gear leaver is not working. Could it be related to the job above or is it a bulb that might be gone.
So in summary I would like to know about the AMP and ILL wires and the bulb at the Auto stick.
Thanks
Thanks
