Courtesy Light
  • Courtesy Light
    95 M plate ssr-x limited. The front courtesy light doesnt work (from either door) only the rear. There doesnt seem to be a switch on the front lights. Any ideas?
    Yeah, yours is like mine used to be. You need a mirror assy with a third switch called DOOR same as the one on the middle switch. mkay
      You might find it's the front door switches. Had that problem on mine a while ago where the light would not come on if I opened the passenger front door. It was bad contacts on the door piller switch. Removed, cleaned and all working perfectly now. I think the switches can "burn" the contacts in if the door is kept open for long periods with the light on (e/g. when working on the car with the door open etc)
      Mike G
