95 M plate ssr-x limited.  The front courtesy light doesnt work (from either door) only the rear. There doesnt seem to be a switch on the front lights. Any ideas?
Courtesy Light
Yeah, yours is like mine used to be. You need a mirror assy with a third switch called DOOR same as the one on the middle switch. mkayOriginally posted by aldo95 M plate ssr-x limited. The front courtesy light doesnt work (from either door) only the rear. There doesnt seem to be a switch on the front lights. Any ideas?3.0 TD SSR-X LTD 1994 Black, sold and passed MOT
You might find it's the front door switches. Had that problem on mine a while ago where the light would not come on if I opened the passenger front door. It was bad contacts on the door piller switch. Removed, cleaned and all working perfectly now. I think the switches can "burn" the contacts in if the door is kept open for long periods with the light on (e/g. when working on the car with the door open etc)Mike G
