stereo/speakers
  • stereo/speakers
    hi guys n girls,
    when i brought my surf the previous owner had replaced the original stereo equipment..i now have a ****** big gap underneath the new stereo is there something out there that will fit this gap??.also i would like to upgrade the speaker system, can anybody through any light on this aswell.. any replies much appreciated.
    nige
    Hi nige,
    I've had a surf that had a single din radio along with, for want of a better description, a plastic slot.
    Re the speakers, be careful with the rear ones - you should find that they're wired up to factory fitted amps. If you wire directly from the radio to the speakers you'll lose the benefit of the amps, which I believe are fitted as standard. No doubt I'll be corrected if I'm wrong.
    The other thing to do is have a good search on the forum, there's bound to be stacks of info on this subject. Try searching for speakers and ICE etc.
    Incidentally, I'm re-living my teenage years (possible a mid life crisis) and have roof mounted (inside of course) a pair of tube sub-woofers (powered by an 1800watt amp).
    Hope that helps,
    Rob
    Constantly Striving to Attain Lower Standards
      Originally posted by nige-s
      hi guys n girls,
      nige
      You need a single Din pocket available from HALFRAUDS
        the amps won't be any benefit as a good qaulity head unit will have a better amp already and unless you go for components then you won't need a crossover
        subs are better in the boot floor as bass sounds are not directional likehigh frequency sounds
