Should I fit a turbo timer?
    Yeah, he loves all our money. But I have had quotes from other places for £800 quid. Was also considering a TOAD CAT1. Can't make my mind up.... So much choice.....so little time.....too little money......
      I have a TOAD ai606 as do many others, its CAT 1, extras if you want them but pretty good value it think, as my fitter said "fit and forget" and so far - touch wood - its been good.
      Tim
        Turbotimer
        Originally posted by Linda
        Mine has an off switch so I only turn it on if on a long journey and am going to use it. Passed MOT with it on, even after the guy asked what it was, and laughed at it!!
        Hi Linda, I`ve just got a turbotimer (ebay) I`ts a GReddy supposibly out of
        a 92 SSRX 2.4, stated as suitable for LN130s I know i dont really need it but as you say it looks cool, Looking at the front from left to right a power button
        a LED screen (min, sec) a select button and a turbotimer time button, my
        question is am i right in thinking the power button is the on/off switch?
        Forgive me if this is sounds like a stupid question but i though i`d better check before fitting it, I dont want the timer on all the time as most of my journys are short, many thanks ian 92 SSRX 2.4 gun grey
          Yup the power button will disable/enable the timer. Most have settings that you can configure as well for duration to keep running etc I have just removed one from a 3rd gen and like all others I have used you can also stop the countdown and kill the engine with a push of a button too.
          Rgds
          Ant
          1996 SSR-G 3.0 TD Intercooler
          Mazda Rotaries too!
            Rgds
            Ant
            Hi Ant, Thanks for the reply and sorry for the delay in responding, I kinda
            worded it wrong but you`ve answer`d what i wanted to know, ie¬ switch on¬
            turbo timed, switch off¬ opperation as normal. Cheers & many thanks,,,Ian
