After driving for a while I find it really difficult to turn the ignition switch all the way off.It turns 1 notch to stop engine but is very difficult to turn the further 2 notches to allow me to remove my key.This only happens after driving,never when turning the ignition when idle,to listen to the radio etc.Any ideas what could be causing this?Would lubrication help(didn't want to do this un advised in case it damaged the inner workings of the ignition barrel)if so please advise type of lube.Cheers
RobD
					RobD
